Ir para o conteúdo principal
Pergunta encerrada
on/off button & back camera
On/off button sometime work, but sometime not. I must press hard and hold in order to make it work.
Back camera have difficulty to focus; mostly the time is out of focus.
Would like to know if this is a hardware failure, if if just something that need to be adjusted, or if it need a replacement.
Thanks,
David
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
David,
Just to be on the safe side regarding the back cam, you can try first a hard reboot and if it doesn't help, then a software restore.
But if you ask me, you have for sure 2 unrelated hardware issues:
1/ The audio and power control cable aka power button flat cable aka PMV cable of your iPhone 5 is starting to go bad. Soon it will stop working completely. This is very common for the iPhone 5, so much so that Apple has a program for repairing this issue for free even if your iPhone is more than 1 year old (check the Support section of their website or visit an Apple Store for details and eligibility), provided that your iPhone has not been tempered with before.
You can replace it yourself, but it is a bit of a PIA. Follow this guide. Be extra careful when prying the battery out. Pry only on the outer edge, never on the edge located near the logic board.
2/ The camera is probably defective too, and needs replacing following this guide.
The reasonable thing would be to have Apple replace the PMV cable (if eligible), THEN you replace the camera.
OR you can just go ahead and do both repairs in one go, since if you are replacing the PMV, you would already have gone through all the steps needed to replace the back cam. Look at the 2 guides and you'll see what I mean.
Imagem de iPhone 5 Audio Control and Power Button Cable
Produto
Imagem de iPhone 5 Rear-Facing Camera
Guia
iPhone 5 Rear-Facing Camera Replacement
Nível de dificuldade:
Moderada
45 minutes - 2 hours
Guia
iPhone 5 Audio Control and Power Button Cable Replacement
Difícil
45 minutes - 3 hours
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 103
