Ir para o conteúdo principal
Released September 2013, identified with model number T100T. 2-in-1 portable with Quad core Intel® Atom™ processor and 2GB of RAM.
80 Perguntas Visualizar todos
Pergunta encerrada
T100TA wont charge - No Lights - Charger OK
Hello,
i'm having troubles with my T100TA as it suddenly won't charge. No Light appears when i plug the adapter.
However, the AC adapter seems to be OK as it charged others devices. I tried with a similar adapter & same probleme.
I wonder if it could be the motherboard or the charging port itself...
As anyone already encountered these problems ?
Thanks in advance !
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Could be the power adapter port on laptop, when you plug it in if it is loose then you need to replace the power port.
Sherri
www.allinonecomputer.com
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you very much Sherri, you're right when i plug the power adapter in, it s a bit loose.
Is there any way to test it ?
Then i better change the PCB than the power port, it would be cheaper don't you think? (finding the sparepart of the power port could be difficult in France)
Is asuspart.eu retailer is reliable ?
Thank you in advance,
Jeremy
por
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,098
