Ir para o conteúdo principal
The Tegra Note 7 is made by Nvidia and branded by graphics firm EVGA. This device is known as the EVGA Tegra Note 7 in the United States, Cherry Mobile Tegra Note 7 in the Philippines, Advent Vega Tegra Note 7 in the United Kingdom, Gigabyte Tegra Note 7 in Australia and New Zealand, Gradiente Tegra Note 7 in Brazil, Gazer Tegra Note 7 in Ukraine and Russia, and XOLO PLAY Tegra Note 7 in India.
What type of new charging port I need to buy?
Hi, my tablet has problem to charge, it is charging only when I'm holding charging cable in specific angle with device. I tried a lot of cables, same result. So problem is in charging port, am I right?
I opened dervice a and now I need to replace it. But what I don't know, what type of port I need to buy.
http://s23.postimg.org/with806d7/2015_01...
Esta é uma boa pergunta?
Pontuação 7
Adicionar um comentário
10 respostas
Solução escolhida
After looking around for solutions to fix the same problem in my own Tegra Note, the best solution I could find wad to open the device up and crimp the top and bottom of the connector a little bit to help keep the contacts touching. The top I/O module of the Note 7 is almost impossible to find for sale, and desoldering the micro USB plug to replace it is very difficult at the least.
Esta resposta foi útil?
Pontuação 7
1 comentário:
how can i open my tegra note ? can anyone share some pics?
My tablet too has the same problem for charging
por
the port breaks because they cut half of it out to fit the case, you can get it swapped out by a phone repair shop for a regular micro usb port and file away a bit of the case to suit.
and alternative if you do not use otg is to take it apart and introduce a charger direct to the battery, if desperate then soldering a regular usb cable to the battery points and using an intelligent charger to prevent overcharging, the better way is to take a case such as the fintie slate 7 one and stitch a QI charging circuit into the case then put a QI 1000mA receiver pad onto the back of the note 7 case underneath the copper sheilding and solder to the battery. with a steady hand you can route the +5v through the original charge circuit but its less hassle and easier to go straight to the battery. the chager will tell you when it is working and switch off when the device is full.
cost - around the same as getting the original port replaced but less risky IMO.
Pontuação 3
2 comentários:
Hi david
If you can explain to me with photos it'll definitely help me a lot
por
Hi David
Pls could you send me some photo instruction how to do Direct charging of battery. Thx my email janokosnac@gmail.com
por
OTG requires a Micro-USB AB port - it's also why your regular MicroUSB cable seems loose.
Pontuação 1
Hi Guys,
My Xolo Tegra Note 7 tablet stopped charging before a month. I gave it to authorized service center. But after 2 days they gave it back saying, as I have downgraded tablet the motherboard is gone. I took it back and shown it to a shop in local Pune market. 2 small shop told me that it's not repairable as the joints are very small and while soldering one thing it would damage tablet.
I got lucky to visit a shop in Pimpri Market. The service guy did an excellent job. He opened the tablet carefully and saw the chipset under magnifying glasses. He found a crack in connector. It's very hard to see with naked eyes.
You don't need to replace any Port. You can get it fixed in a good repair shop which has magnifying glasses
Pontuação 1
Dear sir
After long search for xolo tegra note usb charging port i got to see
the photo of it well my requirment is this usb charging port part were in i tried a lot on all websites but unable to find can u please help me from where can i order this part my mail id is asm.vivatoyota@gmail.com i am from BANGALORE INDIA PLZ help me out
Pontuação 0
Got the same problem but worst thing about it is that xolo center cant fix/repair tegra note because the the serial number is written with lava tegra note, and lava. center ignored me to repair, &&^&! :-(
Pontuação 0
just wired usb cable direct to battery leading it through hole meant for stylus.
Excellent! works spot on thanks so much for the idea, had note 7 sat in pieces trying to find a suitable replacement usb port for the last 8 months, so glad to have my tablet back, it kicks my partners Nexus 7's arse all over the place!
Big thanks to David Collishaw. Cheers
Pontuação 0
1 comentário:
Hi Gerrie
If you could show me how you did it with help of photographs it will be very much helpful
por
Pontuação 0
I have that same problem but how much you can accept from a china phone .you know china stuff
I advice to buy a Samsung one
Pontuação 0
This may be a bit too little too late. But your problem isn't a loose connection. The problem is the substandard component they installed. The charging port is flawed or a second bought from Samsung. The wafer tab in the center of the port is so weak it is where the connection breaks. At first it becomes loose enough it gets pushed up so it does not insert into your plug. Eventually breaks off completely. I made many attempts to contact EVGA, NVIDEA both and they would not hear of it issue a recall or provide me with a replacement.(as I own one of each with same problem) at one time Samsung phones had this problem as well. I never found a fix for this. So I did the same thing to mine and just soildered the wires directly to the battery. It would drain slightly faster having the charger wired directly when not plugged in but worked well for quite some time until the soilder joints gave out.
Pontuação 0
Adicionar a sua resposta
[deleted] será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 12,889
