How do I find replacement USB ports and replace?
Both ports are damaged. Need to find replacement parts and help in installing?
Esta é uma boa pergunta?
Here. Basically the USB ports are fixed to the logic board, however you can use a USB pcmcia card
If this answer is acceptable please return and mark it.
Good luck,
N.
Esta resposta foi útil?
How would it connect to my computer, if both ports are damaged? Would I need a specific card? Thanks for the response.
Um I need the liquid used to de soldier the USB port, anyone know what the liquid is called
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 2,236
