Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
What's wrong with my iPhone?
I recently spilled a Dunkachino on it (coffee and hot chocolate) but it looked like it was only a little bit on the case so I wiped it off and it worked fine. Then, it was dropped and beat up a little bit. A couple hours later when I was in an app the app closed and the apps wouldn't open, then the screen just went black and nothing was responding. Siri worked the first time but not anymore, and it sometimes makes a noise when I plug it in to charge but only if I hold the lock button. I stuck it in rice over night but that didn't work and I tried charging it but it was at 50% when it died and so that didn't turn it on.
Esta é uma boa pergunta?
Pontuação 1
2 comentários
update: the screen has now turned on to the white background w the black apple logo but it's staying at that
por
Please hurry and it's still the apple logo
por
Adicionar um comentário
7 respostas
Solução escolhida
Try rebooting your iPhone first: press and hold (Power Button + Home Button) together for ~10 seconds. If the iPhone does not restart, click then on the Power Button to re-start it.
If this doesn't help, you can try to restore the iPhone by connecting to iTunes. But all the data will be wiped, and in case the restore is not successful, it could be harder to fix.
Finally, whether the above works or not, it would be a good idea to open you iPhone using this guide, clean any liquid residue using a soft toothbrush and 90%+ isopropyl alcohol, dry, re-assemble and test.
EDIT: in case you do see traces of liquid inside the phone, you will need to have it professionally cleaned. Normally this involves removing the logic board from the phone, the shields off from the logic board, cleaning the board in a pro ultrasonic cleaner, rinsing, drying, testing, and fixing anything that seems damaged still.
Very IMPORTANT: make sure not to mix up your screws. Each must go back to its exact position.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thank you! This was really helpful for me!
por
wowwwwww wait to spill your dunkinchino that stuffs expansive dude
Pontuação 1
After I fixed my phone, my back camera and flashlight doesn't work , how do I fix this?
Pontuação 1
I don't know what's wrong it was working fine and all the sudden my phone won't charge unless it's on airplane mode and I don't touch it. it will be plugged in but the battery will decrease if it's receiving any kind of notifications or if it's not on airplane mode. what's wrong with my phone?
Pontuação 1
J'ai charge mon iphone 5s et j'ai deplogue apres une charge 100%.Apres quelques minutes ,il est ferme il ne veut pas ouvrir
Pontuação 1
i never had this problem
Pontuação 1
so i was playing with some friends in the rain and im scared that it might have got water but when i first noticed something that night was a smudge on the like lower bottom of the phone now my iphone 5s has a crack at the top and so now when i turn it on its lines and things now my home screen are nothing just lines.
Pontuação 0
1 comentário:
Are the lines grey or yellow going down the screen? Also it's not really responding when you touch? If the answer is yes to the questions it's a simplex fix your phones LCD screen ribbon are not properly plugged in you need to open the phone and press down on the LCD plug till you hear it snap back into place. If you never repaired a phone let someone do it for you just tell them your LCD screen plug is lose
por
Adicionar a sua resposta
Thomas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 5,589
