Ir para o conteúdo principal
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117 Perguntas Visualizar todos
Why does my image distort when adjusting the angle of my display?
The image distorts when adjusting angle of screen. It will flicker and distort displayed images. Adjusting the angle will cause the problem to stop. When screen angle is changed distortion will occur again. Is it a bad dc inverter board or lcd power cable?
Thanks for any help.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
I suspect that this is caused by a flaky video cable or connection, not anything to do with power. I would try opening the display and replugging each of its connectors. Doing the same for the logic board connection would also be a good idea.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
jafkmw será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 823
