Ir para o conteúdo principal
Model M2453 or M6411 / 300, 366, or 466 MHz G3 processor
How to install a backlight
How to install a Backlight
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Is the backlight completely off or is it dim ??
there are a few possible problems with the backlight
1, the ccfl backlight failed - it would be easier to replace the whole lcd
2, the inverter died - replace the inverter (but sometimes a "new" (used) display assembly is cheaper
3, the inverter cable is scuffed - replace the inverter cable (search on ebay)
4, the inverter cable socket is loose - resolder it/find someone who can resolder it for you (in case you are not able to do that)
since the clamshells are sometimes pretty cheap to find on ebay - i would search there (got my blueberry clamshell for ~30$)
Esta resposta foi útil?
Pontuação 3
1 comentário:
+ for the acceptance
por
Adicionar a sua resposta
bjluchion será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Ao todo: 1,688
