Ir para o conteúdo principal
No signal motherboard issue
Hi my motherboard keep displaying no service after putting correct sim card, ive tested it with diffrent motherboard on same phone to make sure its nothing to do with antennas and stuff, is there any chance to fix that issue on motherboard? If yes, what do i need to replace on logic board? Everything apart from that works.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Solução escolhida
Look in settings, does the phone produce and IMEI #?
Esta resposta foi útil?
Pontuação 0
2 comentários:
If it does produce an IMEI, then this is going to be an antenna issue ot the conventional time/date issue.
Connect it to WiFi to set the correct date/time.
Then toggle airplane mode on and off with correct SIM
por
Still this same my friend
por
Yes it shows me imei, phone number and connects to wifi etc but just shows no service all the time no matter what ill do from typical fixes from the internet and when im trying to make a call its just silence in the speaker.
Pontuação 0
Pontuação 0
maybe i need to replace this part on motherboard?
http://www.ebay.co.uk/itm/Genuine-iPhone...
Pontuação 0
Adicionar a sua resposta
nosferatum2 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 2,168
