Ir para o conteúdo principal
The current line of iPod touch comprises seven (7) different generations.
2619 Perguntas Visualizar todos
Home button sometimes works, sometimes doesnt, How can I repare it?
The home button on my iPod touch 3G (32 GB) is semi functional, sometimes it works perfectly, sometimes I have to press the #%!% thing 5 times just to get it to function.
An example would be double tapping the home button to bring up the multitasking bar (iOS4) or when i had iOS3, to bring up the music notification.. Sometimes it would act as a single button press and exit which ever app im in, and sometimes it would work correctly, and even sometimes I could just press the home button once and it would act as if i pressed it twice..
I understand it may be placed incorrectly or something, would you be able to show me how to take it apart and fix it?
I cannot afford to send it in to get repaired at the moment, so this is the only alternative.
Thanks, I hope to hear from you soon!
Update
I got the device a year ago, I didn't apply for futureshops warranty, would I be eligible to send it to apple?
It isn't too much of a deal, but sometimes I want to smash my iPod to a million pieces because it can be so frustrating lol.
I might just wait until I know there is a jailbreak for 4.0, I have shshs for my iPod touch 3G, which I don't want to lose, in case 4.0 for ipt3g isn't possible.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
I think all products are eligible to send it to apple, just that if its under warranty and doesnt fits the you-done-this-so-there-goes-your-warranty kind of action (jailbreaking for one), it would be free. BUT if its out of warranty or if you have tempered with it in such a way that your warranty is voided, i think you need to pay for whatever service you need. hope this helps.
Source: Read it somewhere before, didnt remember
PS: can go to : http://images.apple.com/legal/warranty/d...
Esta resposta foi útil?
Pontuação 0
1 comentário:
uh change the iPod in the link to iPod and it would work out fine
por
Mine had the same problem... maybe not that serious. Mine was a bit stiff but just trying with each press of the home button apply slightly more pressure on it (it won't break LOL) and hold it for a little longer? That worked for me.
Pontuação 0
i would suggest getting a new bezel and replacing it yourself...
p.s have you tried jailbreakme.com? check it out.
Pontuação 0
Adicionar a sua resposta
Matt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 5,015
