Ir para o conteúdo principal
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Perguntas Visualizar todos
Do I need to replace my LCD
I dropped my ipad and cracked my digitizer. I was able to remove it and am ready to put it back together but the LCD is white and has lines going through it. I tried to perform a hard reset and it did not work. iTunes was able to recognize it and update/sync it but it still is the same. I have taken it back out and reassembled it but it did the same. Do I need to replace the LCD.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If you have reinstalled multiple times and it's still the same then I would try a lcd as its your next option
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Gary será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 91
