Ir para o conteúdo principal
Pergunta encerrada
I cannot view my TV through my computer.
I have the adapter for the mini VGA to VGA.
So I am using that (VGA) to RGB I can not get it to my TV what can I do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Solução escolhida
The reason why you cannot do that is because your iBook mini VGA port is an OUTput not an INput. That means you can only send video through that port.
Greetings!
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
To watch TV on your iBook G4 you need to use USB video acquisition equipment like the Elgato EyeTv system. I use the EyeTV 250 Plus system and I can recommend it.
Here's the Elgato web site link:
http://www.elgato.com/elgato/na/mainmenu...
Pontuação 3
1 comentário:
Try doing this with a monitor.
Pontuação 1
2 comentários:
Please give an explaination for the downvote
por
Sometimes you have to use a lot of latitude to try to figure out what the question asker is trying to do or what their problem is. Just giving a negative vote and not trying to answer the question is cowardly.
por
Uh TV i think needs a HDMI cable?
Pontuação -1
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 830
