Ir para o conteúdo principal
Model A1347. Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
Cannot Power On Mac Mini
The Mac Mini shut down itself during sleep one hour after I add a new USB3 hub to it. I have to unplug cable before I can restart it. (I didn't know it is called SMC reset then). It happened again within an hour, before it cannot revived after it shut off the 3rd time overnight. I can no longer power it on. Can this new hub kill the Mac? I don't want to believe it but they just happened the same time. What can I do next?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Use a self-powered (plugs into wall outlet) USB hub between the device and the new hub.
Yes is is possible for a peripheral to cause problems with computers. The first order of troubleshooting most strange computer behavior is to remove any peripheral.
If this answer is acceptable please remember to return and mark it accepted.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Eric será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 187
