Ir para o conteúdo principal
The 2005 version of Volkswagen Beetle is the upgraded version of the 1998 edition, which obviously came with a large number of improvements and advanced features.
How to replace headlight bulb of vw beetle 2010
how to replace headlight bulb of rigjht side of vw beetle 2010 convertible.
my car does not working high and lower beam.
I follow the introduction. First, I try replace high beam easily. But I can not relace lower beam. Beacuse, it is difficult to unmount the old lower bulb. Could you show me the way and do I have to change both bulbs. If not, it does not working? Thanks.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Other bulbs are held by friction; use pliers to gently pull them out. I cannot understand.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
There are releases in the engine bay you can turn and pull the whole housing out of the car need to be careful not to rip lens off
How To Install Replace Headlight and Bulb Volkswa…: http://youtu.be/ALcVKiHmn9Q
Esta resposta foi útil?
Pontuação 1
1 comentário:
Video posted is for the wrong year, they changed how the headlight works after last model refresh. https://youtu.be/Nu8NnjIRGbI
por
You will find a small locking lever under the hood and close to the rear edge of each headlight "frame" slide it to the opposite direction in it's "groove" and the headlight and the whole assemble will be able to slide out to change the bulb. Just reverse the procedure to lock them back in.
Pontuação 0
Adicionar a sua resposta
kiheon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 19
Ao todo: 3,211
