Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para iPhone xr. Aqui você recebe tudo o que precisa para consertar por conta própria o seu iPhone 6.
Camera not working after drop
Hi there,
I have a customer that dropped his two week old iPhone 6. Screen was broken but housing is still mint because of a good case.
I had ordered a new screen assembly and a new rear camera. Repair went perfectly, it's not my first iPhone 6. But when I powered it up, the camera problem was still the same;
camera app opens up but shows only black image. It is however possible to turn to the front camera.
The flash light isn't working either, that was also the case with iPhone 5 that had faulty cameras.
Any advice? I might advise him to take his phone to the store for warranty. The repair was done without fingerprints and such so they won't notice.
Kind regards,
Renaat
Esta é uma boa pergunta?
Pontuação 4
6 comentários
i also have this same issue. Any luck fixing it?
por
Me too I dropped it and it cracked the screen saver I took it off and the front facing camera doesn’t work now
por
My back phone fell out of my pocket, and fell face first and cracked on the up left corner by my camera and when I try to take a picture both front and back camera are black and my flash doesn’t work.
por
The same thing happened with my iPhone 7 and I went to apple got a screen repair and everything was good but I dropped it today and now the front camera works but the rear doesn’t and neither does the flash and I’ve restarted it a bunch of time but it stays the same
por
Help@Robert G
por
Exibir mais 1 comentário
Adicionar um comentário
6 respostas
Solução escolhida
It's probably the rear camera IC chip needing to be replaced if you already tried replacing the rear camera. I had it done for me once so I know it's possible.
Esta resposta foi útil?
Pontuação 5
2 comentários:
How much will it be to get it replaced?
por
Depends on where you take it to. Probably $60-$80.
por
hope this guide will help you https://support.apple.com/en-us/HT203040
Pontuação 2
2 comentários:
I used the link above ‘support’ & switching phone on & off worked!
Thank you :)
por
After seeing a suggestion to turn phone in and off, instead I refreshed my phone by holding the on/off button and the home button at the same time(like a screenshot).
Hold them both down till the screen goes black. Wait about 8 seconds before turning it on.
The camera worked instantly and so did the flashlight!!
por
You believe or not but for the first time when i dropped my phone the camera din't worked util few days after i accidentally dropped it again then i switched on. Unbelievably the camera started to work again
Pontuação 1
1 comentário:
How exactly did you drop it ?
por
My brother's Iphone 6 + was dropped on the ground and the front of the screen cracked, and now his backfacing camera wont work at all.
the phone wont even switch to the back camera.
Anyone have any idea why?
Pontuação 0
Drop it again it worked for me
Pontuação 0
2 comentários:
You idiot what if it breaks. Dwn the screen breaks
por
Haha that's funny
por
As if you saw bens answer he’s correct but it might still not work if it’s more damaged just to let you know not trying to be offended.
Pontuação 0
Adicionar a sua resposta
RenaatS será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 21
Últimos 30 dias: 66
Ao todo: 146,899
