Headphone jack input and housing
Hello. Is it possible to change the jack input in HTC One without damaging the device? And is it possible to replace the cracked housing. Crack is on the top next to the jack input.
Esta é uma boa pergunta?
Yes & yes.
It is possible to change the 3.5 mm Headphone jack without damaging the device.
In order to do this repair you need to remove the back housing/cover. When you repair the headphone jack, assemble the device with a new housing of your choice.
when replacing the headphone jack, most technicians replace the entire module. Here is the part.
Just make sure you get the one specific to YOUR CARRIER.
Here a back housing replacement.
Here's a teardown on the HTC One M7
Hope this helps.
V/R
Josh.O
Esta resposta foi útil?
Sorry for bothering again. Is it possible to replace jack input without getting new daughterboard? These modules are no longer available in my country.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,841
