No Display, itunes reads it, I hear siri, and it vibrates
So I'm thinking its the backlight is there any other options?
Esta é uma boa pergunta?
99% sure you need a new display
But first make sure the connectors are seeded correctly
Esta resposta foi útil?
That's y I said first make sure the connectors are seeded
Hello con this issue happens when one of the lcd flex gets unplugged(seeded) , Try opening up the device and on the top theres the lcd and digitizer touchscreen cables unplug them and plug them back in . Before you do that make sure the device is turned off by taking out the battery then follow the steps and reconnect the battery back
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 85
