Ir para o conteúdo principal
Repair guides, manuals, and troubleshooting help for a wide variety of Canon series lenses.
17-85mm has the zoom ring blocked.
The zoom ring on my lenses just got blocked. Camera didn't fall down, I grabbed it out of the case and suddenly I can´t zoom in over 17mm on. I don't wanna force it but I am sure this is a solvable problem.
Thanks!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
This is a common problem with that particular lens. I experienced the same after reassembling my lens, when replacing the aperture flex cable (another common problem). Usually this is due to a single screw inside the lens that is blocking the zoom mechanism, and it is not possible to fix without disassembling the lens - which is not trivial.
There are several posts on different forums regarding this particular problem - and there's even the following video tutorial: https://www.youtube.com/watch?v=qml1ukgm...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
me será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 735
