Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
Broken home button prong, can I make an alternate?
Ok, so I did a screen replacement on an iphone 5c. This was the second screen replacement on the same phone with in a 2 week time period. Both times phone was dropped. I replaced the screen and tested as much as I could without the pass code. When they got it home and had the pass code available they found everything functional but, the home button. I pulled it back apart and looked over everything and to my horror found one of the metal contact prongs for the home button had broken off. Is there anyway to fix this? Solder on a piece?
Thanks!
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Ok, I got it I replaced the whole charge port assemble which it was attached to!
por
Boy do I feel like a noob! I didn't properly understand your question (my fault, reading and repairing at same time is difficult!). I don't know why I suggested a home button flex when the prongs you were talking about were a part of the dock connector. Sorry!
por
Adicionar um comentário
2 respostas
Pergunta mais útil
The home button flex for the 5c is very cheap and you don't have to worry about the touch ID sensor either, so go ahead and swap out the flex!
Trying to solder on the piece would not be effective, based upon time and cost expenditure compared to a new flex. You could cause more damage, you could possibly spend hours trying to solder it back on properly only to have it fail a week later, or you could just purchase a new flex for under $5 and install it in under 20 minutes.
I do not want to tell you how to proceed but if I were in your position, I would just replace the flex.
Esta resposta foi útil?
Pontuação 2
3 comentários:
You don't even have to hunt around online for the best deal! You can find it all here on ifixit.
iPhone 5c Home Button Ribbon Cable
por
Hi Eric, I clicked your profile to try and send you a message today--no email listed. I sent you a note through your Device Savers page. Let me know if you got it. (I will delete this comment later).
por
I don't see any messages but I added my email to my about me section.
por
Looks like you got a solution, awesome!
I do a lot of iPhone 5 no home, no power pry damage repair and we have to test the home button function on passcode locked devices, and devices that are not activated. Here are some tricks we've learned:
If you have the device locked, aka sleeping, via the lock/unlock button---then pushing the home button should wake up the phone.
If the device is on iOS 8, and post battery disconnect, so that it is really grumpy for that passcode, you can confirm home button function by doing a hard reset---the power and home button will force the phone to restart when held together for 10 seconds. Both buttons must work for this to happen.
If it is just passcode locked, then flipping up to the camera and then hitting the home button will bring you back to the lock screen.
If it is on the activation wizard after a restore, then click through a few pages. Pushing the home button will bring up a 'cancel/start over/emergency call' dialog.
Pontuação 0
Adicionar a sua resposta
kerri será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,837
