Ir para o conteúdo principal
Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
1004 Perguntas Visualizar todos
Pergunta encerrada
My internal keyboard is not working.
HI,
I had replaced my keyboard yesterday and it was not working with any OS X - back light was on etc...
I put my old keyboard in - and it is doing the same thing. I followed the instructions to a t - but still the same problem
FYI My trackpad ribbon ripped and I am getting a new one tomorrow.
Thank you for your help!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
You'll need to fix the ribbon cable issue first before you can go forward here. Are you sure you didn't damage the other cable.
Esta resposta foi útil?
Pontuação 0
Would the track pad ribbon cable cause this?
And I am sure as I can be... I don think so since it is exactly the same with both keyboards. it works when go into reboot 0 option - I can type my wifi password in. and move the choices (which disk) with the arrow keys it recognizes the pram reset... the back light is on ... its only when you go into the OS X whether setup or full OS X
I did clean the cable with ISO and there is no change.
Pontuação 0
3 comentários:
Did you get the replacement part already?
por
Per USPS it is due here tomorrow
por
Dan do you think the trackpad cable would effect the keyboard?
por
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 155
