Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Pergunta encerrada
mic doesn't work on phone calls but works otherwise
It looks like I need to replace a mic on my iPhone 4s, but it looks like there are 2 mics, and I want to buy and replace the correct part.
I cannot be heard on phone calls unless I use the speaker phone. The mic works for other apps. I need to know which part to replace, and I'm looking for a good video on replacing that part.
Thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
You need to replace the whole charging port assembly with the flex cable, it includes the lower mic, and connector for the home button flex cable. You need to remove and carefully transfer the cover of the old mic to the new one. Here is the iFixit Guide. iPhone 4S Dock Connector Replacement
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you so much! This is the link I was looking for!
por
You will need to replace the dock connector where the bottom microphone is located. The top microphone is used for noise cancelling and speakerphone, as well as face time. However, you say that the mic works for other apps, does this include voice memo? That should use the bottom microphone also, so give recording a memo a try.
Pontuação 1
1 comentário:
Nope. Voice memo doesn't work either. Thanks for the diagnostic.
por
Yes I can make voice recordings. I can cover the mic on the top of the phone and Siri and Google and voice memos still work. People just can't hear me when they call or I call them. I have to use speaker
Pontuação 0
1 comentário:
Same problem! Mic works with, for example, facebook or whatsapp calls and voice memos, but not when dial or receive calls! Any solutions?
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,547
