Ir para o conteúdo principal
Modelo A1502 / processador 2,4, 2,6 ou 2,8 GHz de dois núcleos / Lançado em outubro de 2013
552 Perguntas Visualizar todos
Connectors on display assembly 6 or 11 pins?
I am replacing my display assembly on my late 2013 mac book pro a1502 emc2678. Whilst ordering the new assembly the supplier has ask if the current assembly has 6 or 11 pins. Can anyone answer this please?
Esta é uma boa pergunta?
Pontuação 3
4 comentários
dan, what connector are you exactly referring to. Obviously not the LVDS connector?
por
Sorry but I am unsure what connector they are referring to their email is as follows:
This Macbook has assembled 2 different screens.
One with connections of 40 Pin and 6 Pin and the other one with 40 PIn and 11 PIn.
Please check your connections and let us know which one you need.
Regards
Dan
por
I actually have both MacBooks... the iSight camera on the mid 2013 MacBook Pro Retina has a 6 pin connector, and the mid 2014 MacBook Pro Retina has 11... I know the question is old, but hope that helps.
por
@kristoph can i unplug connector the isight camera ?
por
Adicionar um comentário
3 respostas
Pergunta mais útil
If you have the back off the display (you'll have to do that eventually anyway) on the bottom there's a manufacturers tag with part and model information. The vendor should be able to cross reference from that to identify which screen you need.
I would want a grantee from the vendor that you will not be charged restock or return fees if you do this and still get a wrong part. Also if you pay with credit card or Paypal they will help you if a dispute arises. . . if you write a check you're on your own.
If this answer is acceptable please remember to return and mark it accepted.
Esta resposta foi útil?
Pontuação 1
That's not completely true. I have a late 2013 model (pro 15) and it has a 6 pin camera cable (not 12pin)
All vendors state that is impossible but reality is I have.
Now finding a screen that works mine had been the hardest part.
The backlight is not working on replacement units but works fine with the original broken LCD.
Pontuação 1
They are referring to the camera flex cable. Late 2013 / 2014 models have an 11 pin cable whilst the earlier models have a 6 pin cable.
Pontuação 0
Adicionar a sua resposta
dan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 2,406
