Ir para o conteúdo principal
Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
Use iBook g3 keyboard as external USB keyboard?
Hi. I wondered if it's possible to disassembly the ibook G3 keyboard and connect it somehow to another computer via USB cable. I know the keyboard in the G3 uses a non standard ribbon cable, but maybe it can be linked to a USB interface; am I just dreaming?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
A futile act is "spitting in the wind." So is a selfless but unheeding act that "boomerangs" or has dire consequences the doer hadn't contemplated, an act that "did more harm than good."
"You don't tug on Superman's cape /
You don't spit into the wind'
You don't pull the mask off that old Lone Ranger /
and you don't mess around with Jim."
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Giacomo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 203
