Ir para o conteúdo principal
Repair guides and support for external portable storage by Western Digital including the My Book series, My Passport and others.
Trying to retrieve information from an IDE drive
How can i put my IDE hard drive in another IDE compatible computer to retrieve the information? I know how to install it into the tower, but i cant see whats on the hard drive. I can also see it on the Device list but dont know what to do after that? Any help??
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Was it formatted Mac or PC?
por
Its for PC
por
Adicionar um comentário
2 respostas
Solução escolhida
Using an external adapter may be the way to go. You can hook it up and plug into a USB port to access it. Here's where and what to get: http://eshop.macsales.com/item/Newer%20T...
Esta resposta foi útil?
Pontuação 3
2 comentários:
+ Ralph Use one of those myself frequently.
por
Yep, or you could do that :]
por
With IDE, you have to set master or slaves. If the old drive is on the same cable as the new drive, you must set the jumpers on the back of the drive to either master for new one, slave for old one; OR set it to Cable select, in which case, you need to put the new drive on the end of the cable, old drive in the middle cable port.
Pontuação 2
Adicionar a sua resposta
Tristan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 929
