Ir para o conteúdo principal
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
Repaced digitizer not working
Is there anyway I can identify which version of digitizer I require, as the new one doesn't allow touch, without having the original screen to hand? Thanks
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Jez,
When ordering the digitizer, try to match up your specific model number to the part you are ordering. There are times when you can accidentally order a 4g screen for a wi-fi only model and not have it work. I wouldn't say this is down to revision number on the digitizer itself and the most likely cause is that the part is incorrect for that model itself.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Jez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 344
