Ir para o conteúdo principal
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
Camera shutter doesn't open!
I have been having problems with the camera lately, with the image on the screen being bright red and blue. Now the camera shutter does not open when activating either camera app. Anybody have an idea?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
Strange....
The first place to start would be a software restore (be sure to back up your data first).
After that, I would say try replacing the camera.
If this does not solve the problem, all signs point to logic board.
Good luck!
Esta resposta foi útil?
Pontuação 2
4 comentários:
Yeah, sounds like a software problem. These phones don't have a physical shutter.
por
2 iphones with broken cameras following water damage both displayed only the closed shutter. no prob with software in these instances.
por
good answer +
por
I'm assuming that the software opens the "shutter" when it successfully activates the camera. If the camera won't initialize, then the shutter doesn't open. I'd say the camera is the most likely culprit, not the software. Good call.
por
my camera say cant open
Pontuação 0
I once had the problem. Power Cycled, rebooted, no help.
libmobiledevice restore helped me.
Then replace camera if lmd does not help
Pontuação 0
Adicionar a sua resposta
HUTCH000 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 3,248
