Ir para o conteúdo principal
A laptop manufactured in 2003 from Toshiba.
4 Perguntas Visualizar todos
Why will my device not power on?
The laptop will not power on with battery in. The device still does power on when the power adapter is connected.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
The problem could be related with your power adapter or your battery. On your power adapter, The first component to check is the 2 cords one that connects to the wall and adapter to computer. If the computer doesn't start whit the battery on, the battery is faulty.
Please follow our troubleshooting page. It can help you to check what is causing you problems.
Toshiba Satellite 1415-S105 Troubleshooting
Also, you can check our guide to see how to replace your battery.
Toshiba Satellite 1415-S105 Battery Replacement
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Jason Hofstetter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 320
