Why does my phone not turn on?
I can't get my phone to turn on. It just appears as a black screen.
Esta é uma boa pergunta?
There could be a couple of reasons for the phone not to turn on. Try turning your phone on, by pressing the power button for 7 seconds. If this does not work try to charge your phone. Connect to a charger and let it charge for a 30 minutes and then try to turn it on. As simple as it may see check that the charger is plugged to the wall. If all these don't seem to work, it could be possible that the battery is drained. Try to replace the battery. See Replace Battery Guide
Esta resposta foi útil?
Why isn't my blu 5.0 not charging nor turning on
my answer is more of a question what if the power button is messed up
why dose my phone turn on and off every minutes
My phone don't turn on it got steam in it what do I do
this BLU phone is sucked i just got my phone not even a month but its not working anymore
My blue 5.0not taking any charge nor turning on what's the problem only have a red light but not charging nor turning on
Mine cannot charge I charged it for 9 hours and nothing
I charged mine for 9 hers -_- NOTHING
same problem. just take out the battery and let it cool down and then put it back
Any help pls?, Blu STUDIO 8.0 with in built battery not charging or phone turning.
The way i fox it was when the keys are turned on but the scrern isnt showing then you hold the power button down and if the keys are on let if go off then hold the power buttons until it turns on
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 8,607
2 comentários
my screen is white with BLU ON IT and its been like that for hours.
por Sherrieh Charles
My screen is black with BLU on its been like that for hours
por Mahogany
