Ir para o conteúdo principal
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Perguntas Visualizar todos
Airport not seen in Yosemite
I have a 2011 MacBook Pro that isn't showing the WIFI card. It doesn't show in Safemode or boot disc either. I have tried other WIFI cards, as well as, tried the original card in another MacBook and it worked in that one. So I'm assuming that it's the logic board connector or something. My question is, where on the logic board should I look for damage? Is there a way to repair this damage?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Look at the pins on the connector. Someone else found that was their problem.
If this answer is acceptable please remember to return and mark it accepted.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Any idea what they found?
por
Adicionar a sua resposta
Donavan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 120
