Ir para o conteúdo principal
Modelo A1224 / Início de 2009 / Processador Core 2 Duo de 2,66 GHz
Can't select external drive to boot
We have been running out mac off an external drive since the internal one failed about a month ago and everything has been going smoothly. We had a power flicker today and I went to power up the computer while holding down the option/alt key. I get to the selection screen and it shows the external drive as available for selection but when I click on it, nothing happens! I've tried double clicking, hitting enter, clicking and then hitting enter... the arrow button on the screen darkens and reacts but then nothing happens and the computer does not boot, it just hangs on that screen. The internal HD no longer shows up on this screen anymore. Please Help!!!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Do you have a surge protector or a UPS? Do you have all of the equipment powered via the surge protector/UPS? If not you could have created a back path for the voltage spike to enter into your equipment.
For now you'll need to get a access to a second Mac so you can try repairing your external drive. Or, you could setup a UBS Thumb drive and then use it to boot up.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
loretta será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 11
Ao todo: 464
