Ir para o conteúdo principal
How can I get a replacement Keyboard Connector?
When replacing my keyboard (due to broken keys), the piece on the back of the trackpad was really weak and basically fell apart. This is the where the white ribbon goes. I am unable to type anything without an external keyboard.
Anyway, can I get a replacement for that somewhere? Maybe I just have to replace the trackpad? I guess it depends how difficult it is to replace the connector versus cost. Thanks.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
you can just replace the track pad since it would be cheaper then a top case but that is the only options
Esta resposta foi útil?
Pontuação 0
2 comentários:
I think you're right, but all they sell on ifixit is the entire upper case. do you know where i can find the trackpad?
por
Adicionar a sua resposta
Stuart será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 2,108
