Ir para o conteúdo principal
Repair and disassembly guides for Lexmark printers.
Lexmark Genesis s816 has slowed to a crawl
After several years of very successful use, my multifunctional device slowed to a snails pace when printing anything. It takes over 4 minutes, for example, to print a test page. What could be the problem?
The device is running the latest firmware.
Thanks, Anna
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
HOW TO FIX LEXMARK GENESIS SLOW PRINT
I have also had a lot of problems with slow printing of and on. Never had time to look into the problem until now.
- First try closing network/wifi connection via the display on the printer.
- Power off the printer.
- Close any wifi or other network connections you have been using for the printer. Like a router, mobile device etc.
- Use the USB cable ONLY for printer connection.
Now power the printer on again.
- Make sure the wifi-icon on the display HAS the yellow triangle warning. If not start over again from top.
- Test printing again.
If the problem persists update drivers etc.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
belkjab será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 261
