Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
Touchscreen randomly not functioning after unlocking?
I replaced my iPhone screen today, however I am having some issues with the touchscreen.
When I am using the phone, the screen stays responsive and runs with no issues. However, if I lock my phone and wait for 20 seconds or so, the touchscreen will indefinitely not work upon unlocking the device-despite the actual LCD still functioning perfectly.
However, if I lock and then unlock my phone again immediately after this, the touchscreen will work perfectly without any issues; until I leave the phone locked for another 20 seconds etc...
So far I have reconnected all the flex cables between my new screen and the phone twice (no difference seems to be made) and I have done a hard/soft restart and a reset of my phone.
I hope that anyone could shed any light on this being either a software or hardware issue; as although it seems to be software related, this problem only occured after replacing the screen. No movement of the phone is needed for the touch screen to work/stop working, which just generally confuses me!
Thanks very much in advance for any answers! (:
(Sorry about my avatar... linked to my gaming accounts!)
Esta é uma boa pergunta?
Pontuação 3
2 comentários
Did anybody find any solution for this? I am having the exact same issue after replacing the screen.
por
Hello , Does anyone has solution to this problem? I am having exact same issue after replacing the screen.
por
Adicionar um comentário
5 respostas
Pergunta mais útil
It's a faulty screen seen this issue before
Esta resposta foi útil?
Pontuação 1
I've seen this problem once, faulty LCD.
Confirm by using your old LCD to test
Pontuação 1
I have the same problem with my iphone 5 after replacing battery..
Pontuação 0
hey Matt, how did you resolve your issue?
Pontuação 0
put your phone battery to drain to zero... and then put it on charge after sometime .......... it works for me
Pontuação 0
Adicionar a sua resposta
Matt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 2,896
