2005 Kia Optima rear brake pad replacement
How do you push the rear brake pistons back into the caliber to replace the pads. Is the emergency brake cable a problem? Do the pistons screw back in using a special tool?
Esta é uma boa pergunta?
Randy,
Use a C-clamp and one of the old pads. Turn it in slowly.
That's what I do.
Frank
Esta resposta foi útil?
Thank you!
Randy
I just replaced rear and I used a large pipe wrench turned it til it was all the way pushed in the right spot
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 4,861
