Ir para o conteúdo principal
Repair and disassembly information for Logitech's H800 wireless headset. Supports 2.4GHz & Bluetooth. Released in 2011. Model number: 981-000337.
How about the low-battery annoying beeping?
Hello,
I own the same device, and I am looking for a solution to the 3 seconds beeping that happens for hours before the battery runs low and just don't let me make the best out of the headsets. Is it possible to identify and cut the line that is responsible for that sound permanently? I would know if the battery is low when sound no longer comes out, as easy as that.
The engineer behind this idea is plain stupid, you don't tell people that the highway is no longer usable at a certain distance by placing nails on the road every meter.
Could you please kindly and generously guide me with your high wisdom through this deed?
Thank you,
Esta é uma boa pergunta?
Pontuação 11
6 comentários
Annoying doesn't begin to describe it.
por
Ohh My God logitech - please fire whoever is in charge of this beeping!!!!! YOu suck!!!!!!!!!!
por
I got tws-i8x Bluetooth earbuds. When battery reach 30% the sound of beep and Please recharge keep popping up every 10 second.
There is anyway I can disable the earbuds beep and the sound notification at least to 10 or 5% which more convenience?
por
Please take the beeping off can't enjoy headphones make you want to trash them or send them back
por
I'm in the same situation as you guys look I think what they did is dumb because my headphones last a whopping 24 hours but start beeping at 30% non stop every 2 mins its dumb because I know for a FACT that there is 7 hours and 20 mins remaining I DID THE MATH so really I have to charge it after only 17 hours instead because of this annoying choice of when it beeps like for the love of god JUST MAKE IT 5% EVERYONE WOULD ENJOY IT MUCH MORE sorry for rant but yea same problem I need someone to help fix :/
por
Exibir mais 1 comentário
Adicionar um comentário
3 respostas
Solução escolhida
Mine does the same thing. What I am going to do is buy a super high powered cell phone battery
and replace the inner battery with it. I did the same thing to a pair of H600's . Put 3 AA Battery holders
on the headset around the top and removed the little 'chicklet', battery that was inside.
They now run for about 96 hours instead of the normal 5 hours..
Esta resposta foi útil?
Pontuação 5
3 comentários:
Would you do a video of this or a guide?
por
Does it still charge via the USB or externally ?
por
Plz do a video
por
In Ubuntu, you can go to sound/sound effects
and mute alert volume:
Pontuação 2
3 comentários:
Does this help ? From what I understand the beep is generated BY THE HEADSET ?
por
Back then it seemed to solve the problem, but now it doesn't stop the beeping :(
por
2020 and I stilll hve the same problem :(
por
Just send them back no point owning them for half the charge its guarnteeing
Pontuação 0
Adicionar a sua resposta
Houssam será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 24
Últimos 30 dias: 123
Ao todo: 78,071
