How to fix DSI XL troubleshooting
an error has occurred.press and hold the power button to turn the system off.please see the nintendo dsi operations manual for help troubleshooting.
help me!!!!
Esta é uma boa pergunta?
help me!!!!
The only thing that I know of that you can try is to replace the wifi board. This is sometimes the cause of this problem. If that does not fix it then you would have to replace the memory chip (from what I've heard).
You can try to just remove and re install the WiFi board...sometimes it just gets loose.
Someone else here might be able to tell you which chip would need to be replaced. I've never bothered with learning about it since these aren't worth much anymore.
I hope this helps.
Esta resposta foi útil?
i can’t get my nintendo to work
hi can’t get my ninteno to turn on
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 930
