Ir para o conteúdo principal
The Huawei H881C, also known as the Huawei Ascend Plus, or Ace is an entry level prepaid smart phone from the carrier Straight Talk, a subsidiary of Tracfone.
Why does my phone keep turning off randomly?
It turns on when its charging but it just shuts off at the same time. It also says its low battery and once i plug it in it says 100% in just a minute.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Most probably the problem is in your battery.
Remove the battery and clean the battery pins with an alcohol and a toothbrush. Clean the phone pin-outs too. Sometimes the contacts between the battery and the phone makes problems like this.
Next - new battery.
Regards.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Lu castor será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Ao todo: 3,850
