Diagnostics expertise required re:- LED and potential fault finding?
Hi.
I had a hellish day yesterday. For weeks now, my Mac had started to overheat so I installed smcfancontrol and ran CPU fan at full tilt. It helped a lot. Coming back to mac in the morning I was sometimes seeing 15C. It freezes at around 40C.
Lately, I have been working and the screen goes grey from the top down with a message in many languages telling me it has to shut down.
So I stripped it and checked GPU and CPU as per your excellent guide. Brilliant resource. Many thanks for being there.
It's a 7300 on this model and the chip looks a bit bluish like it has really overheated.
Bear in mind, after a period of cooldown, it was restarting and working fine until it would shut itself down again.
The thermal paste was hard so I scraped it off, cleaned and re-applied.
All fans and ducts are clear. No real dust to speak of. In general, quite a tidy internals.
I put it back together (several times). I realised I'd left CPU sensor cable off.
Anyway, to get to the crux of the matter.
LED's.
I cannot remember the exact order of events leading to the current status.
I had it at a stage yesterday where 3 lit and remained lit but white led was steady. I then removed logic board to check thermal paste. It had spread over some transistors on the GPU. I cleaned it off again and re-applied a little less but sufficient.
Put it all back together again.
Now it starts. When power button is pressed LED's 1, 2 and 3 light. 3 goes off straight away and white light stays steady.
This normally boots to desktop within 25 seconds.
It is operating normally as smcfancontrol spins up the CPU heatsink fan at 32 seconds in but white LED stays on.
My concerns are:-
1) I am running this with cover off. Does iSight camera need to be plugged in to send a signal that it is working to enable screen to be switched on? It doesn't seem to make any difference to LEDs.
2) Why would GPU, logic board or LCD suddenly not work where it was fine before? I have been very careful handling all components.
3) If I buy a Mini DVI to VGA and connect secondary monitor, will it work if fault is purely LCD? I never like to assume but I am guessing it will.
4) Money is very tight at present. Do I go with GPU first or logic board? The LED info I have seen on here suggests GPU first (most expensive component).
5) Will this board run a 1Gb Nvidia MXM chip or am I restricted to a 7300/7600GT GPU?
6) This may seem a stupid question but I have had it to pieces so many times. I simply do not want to take it back to bare bones again. Got down to 8 minutes on strip down! Is it possible that I have left a cable off which would give these LED symptoms. I guess not but...
Apologies for the long description but hopefully it is detailed enough to help you to help me.
I am getting desperate with this.
Esta é uma boa pergunta?
2 comentários
@Grumpy Greyhound, post an image of the broken component as well as its location. that will help us to identify what it is and what its purpose it. May help you in getting your computer back.
por oldturkey03
@oldturkey03
Thanks for that. I have had a quick search on how to upload an image but it is beyond me. It talks about Media Manager, takes me to Dozuki and this and that.
Can I not just host an image on image shack or similar and link to it?
Here goes trying a link:-
[URL=https://imageshack.com/i/p9ttSvbSp][IMG=http://imagizer.imageshack.us/v2/800x600...][/IMG][/URL]
por Grumpy Greyhound
