Ir para o conteúdo principal
Why won't my device respond to commands if it is on?
My device is on, but it refuses to respond to any command. It seems frozen.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
1. Try to lock and unlock device (Soft Reset). If problem persists, turn device off, wait a few seconds, then turn back on. If soft reset does not work, see guide for Replacing Home Button. Once device is working again, close all applications and websites that may be too intense for device.
2. Touchscreen is not working. Verify that protective cover, or case, is not interfering with touchscreen sensitivity. Perform a soft reset. Identify if operating system is affecting touchscreen functionality. Verify that there are no cracks on the display. If there are cracks on the display, see guide for Replacing the Display.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Bruna será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 235
