Ir para o conteúdo principal
The third generation of Galaxy Tab including a 7.0, 8.0 and 10.1 inch display versions, as well as the Galaxy Tab 3 Lite 7.0. Released in July 2013.
phone getting switch off frequently...
my device is getting off frequently and there is a variance in battery after that plugged out like some times it increases and some times suddenly there will be a drop in battery .... is this the prob with the battery or the software..... and for the regular use the device runs smoothly ..... but when i open a fb or other browsing sites the device gets off.... :(....plz help me out :( :(
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
90% this is battery problem. Maybe when you start the browser the WiFi module increase consumption and this is a reason for shutting down. Unstable battery indicator also shows that the problem is into battery.
To be sure that this isn't a SW problem, you can do a factory reset first from the menu or from the Android System Recovery menu:
Samsung Galaxy Tab 3 Password Lock/Hard Reset
!!!This will erase all your information. Do a backup first!
Regards.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
balu será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 93
