Ir para o conteúdo principal
Improved second generation Google-branded tablet with a 7" screen.
How to Replace broken accellerometer?
Which is the procedure, if exist, to replace the accellerometer? and how much can cost the replacing parts?
Thank for your help!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Hey - what are you trying to do ?
You would have to identify the chip - search for a replacement or salvage from a broken board, and since it will most likely be a BGA package you will need a hot air rework station.
I would say a replacement should cost ~$15-$25 per chip
Esta resposta foi útil?
Pontuação 0
1 comentário:
I ask - what are you trying to do - simply because its such a specific problem. How did you diagnose a broken accelerometer.
por
Maybe you should watch this first:
https://www.youtube.com/watch?v=LLCAeBe2...
Pontuação 0
Adicionar a sua resposta
Roberto Zoboli será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 994
