Ir para o conteúdo principal
The UP! Plus 2 is a 3D printer manufactured by PP3DP for home or professional use and is capable of printing objects of up to 140W x 140D x 135H (mm).
Printer that is not initializing correctly and skipping?
I've had my printer for a while now, and I've run into an issue where my printer will start skipping and pushing it's y-limit boundary. There is no "click" of the switch in the back.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
If your printer is going too far back and there is no audible click then your y-limit is malfunctioning. This means your mechanical limit switch is either not connected or malfunctioned and should be replaced.
Esta resposta foi útil?
Pontuação 1
make sure the firmware is updated and check the bed range settings in your slicing software.
Pontuação 0
Adicionar a sua resposta
Spencer Jefferson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 448
