What if my Nokia Lumia 635 does not turn on?
I have tried turning on my phone and the screen does not even light up. I don't know if the battery is dead or what is happening?
Esta é uma boa pergunta?
No matter what you do, you can't get your Nokia Lumia 635 to turn on. Here are some things for you to look at:
(1)Drained/bad battery
If your Nokia Lumia 635 won't turn on, especially if it has not been used recently, you may simply have a drained battery. Plug your Nokia Lumia 635 into your computer or AC adapter and see if anything happens. Ideally your Nokia Lumia 635 will recognize it has been connected to a power source and charge its battery. If it will no longer charge, the battery must be replaced. You can purchase affordable batteries online.
(2)Bad display
It is possible that it appears nothing is happening because the display is bad. If you hold the Nokia Lumia 635 up to your ear you should be able to hear the hard drive spinning and feel it vibrate. If the Nokia Lumia 635 sounds like it is working properly but nothing is visible, it is possible the display is bad and must be replaced.
(3)Bad Power button connection
If the Power button is not seated correctly, it is possible that the Nokia Lumia 635 will not turn on. Be sure that the bar on the Power button is completely flipped down to ensure a positive connection.
Esta resposta foi útil?
there is NO hard drive in this phone... seriously... who wrote this?
Thought the first tip worked for me, thanks soo much
@oldturkey03 @pccheese, how does a post like this get a score of "8"?
"...you should hear the hard drive spinning and hear it vibrate"?!!!
@avanteguarde the funny thing that most the people who upvoted probably created their accounts just to do so.
Maybe the 635 is actually a Zune 30GB with a different case!!
@avanteguarde LMBO that is funny. Good thing it received the last vote 2 years ago and does not look like anything but a bad answer. You know what to do if you do not like an answer that is blatantly wrong like this one.....;-)
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 43,504
