Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Pergunta encerrada
Recovery mode after screen repair?!
Put a new screen on, worked fine, but screen had dead pixels. changed it again, now only shows red itunes logo. tried restoring with two different computers, two different cables, and in and out of DFU mode. Itunes is updated. help?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
did the restore fail or succeed? if it succeeded, it sounds like the home button is pushed down and the phone is booting to recovery mode.
Esta resposta foi útil?
Pontuação 0
4 comentários:
failed. error 3 most of the time
por
look closely at the board near the battery connector, dock connector, lcd/cameras connector----see if you can find any 'fingernail damage' to the board
por
Seriously cant find any. even compared to a perfect board and they seem identical.
por
ok, and make sure to look under the black sticker at dock connector. Try putting the board in a known good housing and see if it will solve.
por
Try fix iPhone stuck in recovery mode by following these instructions:
http://www.any-data-recovery.com/topics/...
Only one signal click!
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 216
