Ir para o conteúdo principal
The Motorola Defy was released in October 2010, and was designed to fill a niche area of the smartphone sector.
Why are my phone calls not connecting?
The calls are being dropped, cannot clearly hear the person on the line, or will not connect at all.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Phones calls may not connect if there is a poor signal or the antenna is broken. If the signal is poor, this may be because the cell reception is bad in the area you are in. If the area you are in is supposed to be good, then the antenna may be broken and must be replaced.
Esta resposta foi útil?
Pontuação 0
Please seject me properly gauide
Pontuação 0
Adicionar a sua resposta
Morgan Roark será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 238
