Ir para o conteúdo principal
What is the fan like noise on the left side?
there is a noise as if there is a fan rubbing on the left side on my PB. you only talk of a right fan. what is this pls? is there left fan?
thank you for all your good work. it help me very much.
claus
Esta é uma boa pergunta?
Pontuação -1
1 comentário
thanks Andrew, great help.
por
Adicionar um comentário
1 resposta
Solução escolhida
There is a left fan, if you look at the device page there is a repair guide linked there, I will give you links to both.
Device page:
PowerBook G4 Aluminum 15" 1.5-1.67 GHz
Guide:
PowerBook G4 Aluminum 15" 1.5-1.67 GHz Left Fan Replacement
Is there anything actually wrong with the fan? Or were you just curious as to what the fan like noise was?
Hope this helps!
Esta resposta foi útil?
Pontuação 1
3 comentários:
Last plus Andrew. Its been a pleasure meeting you. Ralph
por
Why last plus? Where are you off to?
por
Been thinking of other projects. Waiting to hear from ifixit. Ralph
por
Adicionar a sua resposta
macwallah será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 659
