The fan blades won't spin--how to fix?
I can hear the motor whirring inside when I first turn it on but it takes awhile for the fan blades to actually start spinning. How can I fix this?
Esta é uma boa pergunta?
The fan blades could be damaged. You can replace the blades, or see if there is anything blocking their movement. There could also be a problem with the motor as a whole. Use this guide to check the fan blades and replace the motor.
Esta resposta foi útil?
Últimas 24 horas: 8
Últimos 7 dias: 9
Últimos 30 dias: 16
Duração total: 12,784
