Ir para o conteúdo principal
This device is an at-home beverage machine made by SodaStream. The purpose of this device is to make carbonated beverages in the convenience of your own home with the use of syrups and the machine. This particular model was originally manufactured in approximately 2007.
Whats the difference between a broken seal and old washers?
My machine is not producing carbonated beverages, I have had this machine for a long time and have had no problems. My CO2 tank is full and I can not determine any other issues.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
This problem could be caused by either worn out washers or a broken air tight seal. The main difference is that a whooshing noise will be heard if the air tight seal is broken. Try carbonating a beverage and listen very carefully; if the air tight seal is broken the noise will emit from the adapter.​
Esta resposta foi útil?
Pontuação 1
our Sodastream works well, however the seal at the top of the bottle entry leaks and water "blows by "
and leaks down the bottle and makes a mess.
I cannot find a replacement gasket online???
cujim
Pontuação 0
Adicionar a sua resposta
Katie Fetters será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 52
Ao todo: 1,903
