Ir para o conteúdo principal
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Purchase without reading specs Logic upgrade
Hi
I bought a late 2013 MBP entry level unit not realising that the Nvidia GPU had been excluded from the build
Is it posable to purchase the next logic board up with the duel GPU fitted?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
It would appear to be so, but it also appears there are no DG logic boards here in stock.
May be faster, and cheaper in the long term to sell the wrong MPB and purchase the one you desire. A logic board swap is a very difficult DIY repair - essentially you dismantle and then reassemble the entire machine (a lot can go wrong).
It's one thing to swap a logic board on a nonfunctional machine to get it functioning, but another to tear down a working box, try to sell just the logic board, & buy the logic board replacement. I think you'd get more for the entire working machine than for just the logic board.
Google Shopping is your friend.
If this answer is acceptable please remember to return and mark it.
Imagem de Replace a 2.0 GHz Core i7 logic board (motherboard) compatible with the Late 2013 Integrated Graphics model MacBook Pro 15" Retina laptop. Includes RAM. Included Ports: 2 Thunderbolt (Mini Display Port), USB 3.0. Fix processing issues like unexpected shutdowns, reboots, or water damage.
Produto
MacBook Pro 15" Retina (Late 2013, Integrated Graphics) 2.0 GHz Logic Board
$134.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Bionic Media será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 105
