Ir para o conteúdo principal
The Planet Eclipse Etha is a mid-range electronic paintball marker released in October 2011. It offers a lower-cost alternative to one of Planet Eclipse's most popular paintball guns, the Geo.
6 Perguntas Visualizar todos
How Do I Stop the Gas From Venting Down the Barrel?
My gas vents quickly down barrel as soon as the marker is gassed up. What is wrong here?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
The most likely cause of this is one of the O-rings in the bolt is dirty or damaged. Nothing to worry about, but you may need to replace a couple of them. Look over here for our O-ring replacement guide. Once the bolt is disassembled, check all the O-rings for damage. Replace any that show damage, lubricate all O-rings, and reassemble the bolt.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Evan Hench será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 239
