Ir para o conteúdo principal
This page contains replacement guides and a troubleshooting section for the Craftsman Scroller Saw Double Insulated 5/8" Stroke-Variable Speed (Model 315.10721). This handsaw was manufactured in 1979 by Sears, Roebuck and Co.
Why is the trigger on the saw sticking?
When I press the trigger to turn on the saw, the button seems to get stuck frequently. What can I do to solve this issue?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Either it's choked with dust/grease/debris or it may be broken inside (lock button or actual micro switch).
You'll have to examine it closely - use some spray cleaner, if that doesn't work take it apart and check the trigger for damage.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Riley Hilliker será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Ao todo: 178
